vcVolumeDetectorTestMethod
Parent: Enum
Referenced by: vcVolumeDetector.TestMethod
How to access:
import vcCore as vc vc.vcVolumeDetectorTestMethod.<ENUM_VALUE> # replace <ENUM_VALUE> with the desired enum value
Enums
| Value | Description |
| CENTER_INSIDE | Checks if center of bounding box of specified node(s) is inside volume detector. |
| INSIDE | Checks if bounding box of specified node(s) is completely inside volume detector. |
| INTERSECT | Checks if specified node(s) intersects the surface of volume detector. This is similar to using a collision detector that detects the collision of geometry. |
